ABS Light With No Codes
Thanks for the advice! I just bought it and my trusted mechanic didn't feel anything excessive in the front end. There was a tiny amount of play at the pitman, but not a lot. The inner tie rod did have excessive play and was replaced.
I have pads and rotors coming from Rock Auto in the next day or so. My plan is to pull the sensors, inspect, clean and install the new front brake rotors and pads. If if cleaning the sensors doesn't take care of it, I'll go for new hubs with sensors up front and see what that does. Thanks again. I'll know by sometime next week, what happened or was found on inspection.
Sometimes they do not have play but will make noise when the wheel is spinning, either a grinding noise or sometimes a tick like noise like a ping-ping sound or any kind of scraping noise, they should be dead silent ideally.
Hobert
Downers Grove, IL
Update:
Sunday 11/7...
ABS light and chime still flashing, staying on a while, turns off for brief stretches and the cycle repeats for as long as I am driving over 55 MPH. Get off the highway, driving local roads 30 - 45 MPH and everything is peaceful again.
New downstream O2 sensors cleared that code, which has remained off for two days.
I think at this point, I can rule out the possibility that the O2 sensors or the CEL code they created had anything to do with what the ABS light/chime is doing. Not related.
I am due for new brakes. I will start with replacing the front pads and rotors. I'll be removing the ABS sensors to clean them of any debris and will brush off any rust that may be on the hub. See if that does anything. If not, front ABS sensors are really pretty cheap. I may just buy new front sensors with my front brakes anyway. No sense in taking rotors off twice for $30-40 bucks. Not worth the added time...
I had a 2001 yukon XL, in 276000 miles I had this issue twice. Each time I had front hubs replaced twice fixing the problem.
MassHoe04
MassHoe04
Western MA
I may end up doing hubs, but current cash flow is forcing me to split into smaller jobs. I'll be doing front rotors, pads and giving a try on ABS sensor clean this week. It may be a couple more weeks for hubs, when I have funds.
MassHoe04
MassHoe04
Western MA
I managed to find my Zurich scanner does read ABS codes. Not live ABS data, but at least it sees the codes. History was C0225. Still happens mostly at 55+ MPH. I pulled the connector and sprayed with BrakeKleen, in case there was dirt or oil on there. See what happens tomorrow...
MassHoe04
MassHoe04
Western MA
No change after cleaning and snapping the connector tight. Still pinging/dinging at me on the highway, but not after I slow down off the highway.
I read somewhere tire size could throw off the system? I did swap out to some stock rims. They came with slightly smaller than stock (245/75 R16), but they are all the same size. The C0225 code indicates only left front issue (open circuit).
I am still hoping it is just the ground to the chassis from the - battery, the body to block ground strap, or the EBCM.
I looked deeper into the menu and there are codes there, but no stored codes or active check engine light. I have been using cruise control, brake lights work and there doesn't seem to be anything wrong with the transmission shifting. Are these old codes that have been fixed, maybe? It also listed a couple of evap codes, but here are the ones in that history related to things that all seem to work fine... Are these active or just historical?
If active, are they possibly related to possible poor grounds?
Walchit
I'm having ABS issues right now too. Check the wire really good on that sensor, mine was broken in at least 2 places. I soldered one, then just bought a new sensor. This thread has me dreading having to buy hubs.
YukonRog
Auburn, CA
Just saw this thread and the post on tire size being questioned. From what I've read one tire worn 1/4" smaller in diameter can throw ABS codes as well as make your Transfer Case engage all wheel drive off and on. May be worth checking. I know you've had two sets of tires on the rig with the same results, just wondering what the wear is on both. Although I'm leaning towards bad wiring on that front sensor.
Very unlikely wheel or tire size would have anything to do with it unless you were running 3 different sized wheels
looks like the front left abs sensor has a broken wire or the hub is bad, swap left & right sensors and see if the problem follows
you also have a bad brake switch, which is probably related to the cruise control circuit (maybe) you def won't have any cruise control
and you might have a bad torque converter solenoid, not real big on the inner workings of the trans but that would be my first guess
MassHoe04
MassHoe04
Western MA
Thanks for your advice! - Greatly appreciated!!
I will offer some additional information, in effort to see if anything jumps out at you...
Here is/are the weird thing(s)...
Cruise works fine. Used it all weekend on the highway. On/Off/resume/accel all work as expected and maintained speed perfectly.
Transmission shifts as expected and smoothly. Using all gears and nothing unusual.
Brake lights work and have not been flaky at all.
The ABS light is only above 50 or 55 MPH on the highway.
No ABS codes anywhere in the scanner after I cleared the C0225 Sunday night.
I have been doing in-town driving since them and no speeds over 50 around town.
No ABS light/chime activations locally. Ever. Just highway...
I cleared all those codes and scanned this morning. The same 8 codes are back plus 3 new ones... Knock Sensor Circuit Low Voltage, Knock Sensor 2 Bank 2 Low Voltage.
Still, nothing tripping CEL and main scan says no DTMs stored. These codes I see are only visible in the "Chevrolet OEM Enhanced - ECM" menu on my scanner.
Am I crazy to still lean towards possible grounding issues causing these weird codes while everything seems to be working functionally just fine?
It just doesn't seem like any of the codes listed in that sub-menu on my scanner are legitimate problems.
I'll be doing front brakes, checking some ground connections Friday, when I am off from work.
I will swap left and right ABS sensor while I am in there with the rotors off.
then they must be historical codes, must be things that a previous owner fixed because a bad knock sensor would def have a check engine light on
when you swap the sensor, if the code follows then it is a bad sensor if it stays on left then it'a bad hub
I am guessing it's not really a broken wire then because it wouldn't read at all and you would have trouble coming to a complete stop because the abs would be kicking in
swapping the abs sensor is simple, it's 1 bolt and a couple clips that hold the wire along the control arm and then it unclips from the harness. left & right are identical.
gm_bum1000
