ABS Light.......
clean454
hmm alright ill thro a code reader on it and check it out, this mite be the reason why my breaks are wearn weird
rucr8z2
Saluda,Va.
when the dash throws an ABS code the ABS system is shut down and only regular braking system is in effect. so if your brakes are wearin differently from side to side then check for a caliper hanging up or a rubber brake hose bad.
ravingmadman
Chief Knuckle Buster
Greater Seattle
That's good poop. I didn't realize the speedo sensor also ran the ABS. That actually explains some other minor quirks I've been having with my Hoe. I'll post a new thread so as not to thread jack. Thanks again.
