The wives tales about oil are many and passed down from generation to generation. Grandads and dads oil isn't what we're using today. Oil has improved greatly. Maybe it's time for some new wives tales
I've seen virgin oil analysis on new old stock of a can of 1970 30w Quaker State. Analysis showed the TBN# to be ZERO
. No wonder our engines didn't last very long, and we even changed our oil every 3000 miles.
A new engine apon initial build is assembled with lube on surfaces that need it. Within seconds after first startup sump oil replaces the assembly lube. For the remainder of an engines life there is a permanent film of oil on everything. oil clings. It's a wonderful property of oil, especially todays oil.
Some engines don't have a oil pump. They rely 100% on "splash" for lubrication.
Dave/Geotrash: Toyotas burning oil???? Just so you know, not mine. I have a 2007 Toyota FJ Cruiser all w/aluminum gasoline 4.0L w/VVT. I bought it used w/20k miles in Jan of 2009. It now has 220k miles. It's been my daily driver since Jan 2009. Toyota recommends premium unleaded and changing the oil every 7500 miles. It has never had any fuel other than regular unleaded, and the oil and filter have never been changed at less than 10,000 miles. I've done 13 UOA on the various brands and wts of oil I've used in it. Thru UOA I've discovered it's easy on oil. I've taken its oil change interval out to as far as 18,000+ miles. It doesn't burn or leak any oil. It's never been in a shop for any reason. To date it has never thrown a code. Are there FJs out there that burn and/or leak oil? Certainly. Some folks can destroy a metal ball with a rubber hammer.
I've been discovering for the past 3.5 yrs and 5 UOA that the 6.2L L92 is completely different animal. It's very ******* the oil.
