I'm running 10W30 in it. Idle pressure according to cluster gauge is about 22 psi hot. This engine has 121k miles on it, original oiling system as far as I know, although the pan gasket has been replaced according to records. Is that an acceptable oil pressure?
edit: maybe I should clarify. It runs one line above the first big line which I think is 20 (the big line is 20). It's a bit over 40 hot when the engine is spinning at pretty much any driving rpm.
