Adding subwoofer to 2016 Suburban LT bose
NO4NSHIT
I don't know what a g-pack is, but if I had to guess when you turn it up either there is insufficient power, or insufficient ground (or both) or your interface is feeding back a improper ohm load overloading the factory amp which makes it shut off.
I would get a meter and start checking
if you suspect the interface bypass it and run rca's to the sub inputs from a external media source, increase the input and see if it works stand alone
i'm just guessing I have no idea what you have hooked up or how it is connected, your going to have to troubleshoot it section by section
My bad. Voice text messed that up.. PAC RP5-GM11 is what my double DIN Kenwood is plugged into.. and basically I can play it and it plays perfectly but if I turn the amp gain up it shuts it off like my amps don't go on protector anything it just like cuts it out like the both amp cuts it out and then I have to turn the system off and turn it back on and it plays again perfectly fine I just need to know how I can bypass the Bose amp without having to put another amp in there to bypass that amp if I bypass the amp the Bose amp will sound still come out of my speakers or do I need to get another amp to replace it with
S
studbeefcake
Hijacking your thread.. I thought we were all here to help each other out.. I'm so a confused as to y you would even say i hijacked your thread...
The title of this thread is
Adding subwoofer to 2016 Suburban LT bose​
Now the latest posts are about a 2003 with aftermarkets already installed. Back in the old days most forums had rules about not taking over someone's thread and starting your own with whatever your question was. That way in the future when someone is searching the forum it's easy to find the right information.
NO4NSHIT
I wasnt trying to hijack your thread don't be all butt hurt about it I definitely wasn't trying to steal your lime light.. I just seen where someone said that guy knew his shit about the Bose amplifier I apologize if shielded you from any attention from anyone on here I just needed my bass back at full capacity and I'm not really wanting to cut shit again.. I've got 4 2500 watt Max subs in 2.5 cuz sq ft per speaker just barely shaking my rear view mirror I need my bass back... It's really painful way more painful than me "hijacking your thread" totally not what I was at all trying to do..
I'm not on GMT800.. I have no idea how to tell which platform I'm in I figured it was but ok no worries
the 2003 is a gmt800, there is a section on this forum for obs 1991-1999/gmt800-nbs 2000-2006/gmt900-nnbs 2017-2014/k2 2015-2020/t2 2021+/ev, etc
you may find that posting in the proper section will get you more help from people that are knowledgeable about the 2003-2006 vehicles
for example:-->https://www.tahoeyukonforum.com/forums/audio-electronics.22/
rick1024
Fort Worth Texas
two options
or
i have the first, its good, but it doesnt stay on during road trips. if its really hot outside it will also shut off after a while, and its not the amp either. im gonna try the second option once the cash flow is there. i also like that the second option has a cross over that can be tuned. the first option does not
rick1024
Fort Worth Texas
the fact you listed the max handling of the subs and not the rms says a lot. just take it to best buy or audio express.
BUhl14
