after headers: grinding feeling in gas pedal
DaUsedMCR
San Bernardino, CA
ever since the install of the LPP LTs, i feel a grinding or rubbing feeling from the gas pedal when i go over bumps, it seems... its that the y-pipe rubbing?
hoe
dude, I can sell you a stock headers and wye pipe if you would like to revert back to stock. But I think the header install is messed up, or is resting on your frame. Or ORY is touching the tranny allowing vibrations etc
bkboatnsleds
McHenry, IL
I'd agree. I had a weird vibration after my headers.. sounded / felt HORRID! It was as simple as a heat shield hitting the header. Check everywhere.. make sure its not touching the frame - etc.
DaUsedMCR
DaUsedMCR
San Bernardino, CA
ill take a look when i get a chance. thanks for the help. its only when i go over bumps, it vibrates in the pedal a bit. other than that, its great.
bkboatnsleds
McHenry, IL
I'd still check - Its probably something thats just so close... Mine was noise was only at high rpm's when I'd STOMP on it.. And the motor would flex it would then lean into the heat shield.. Does not take much for noise / vibrations to resonate
MushroomMario
