After market wheels
My01yuk
Dallas Tx
I took my yukon to discount tire the other day to have my wheels looked at. I wanted to get the offset of them if possible. When I got them in March a few days later I noticed on three of the wheels the lug nuts sat back deep in the wheels(meaning you could not see the lug nuts if you were standing over the wheel looking down at it). One of the wheels you could clearly see the lug nuts so this made me think that wheel was a different offset than the other three. Took it back to get this corrected and they said they had to order the wheel because they did not have that offset in stock. Said it would a week, went back and still no wheel, said should be in a day or two. Went back and they were searching for it but could not confirm it was in the shop. an hour later nothing so I started bitching at the owner and all of a sudden he found it. Got it aligned after that, now I'm noticing a little shimmy when I drive, nothing bad but i notice it and it just started about a week or tow ago.
So I decided to go to discount tire and see if they could confirm that i had 4 wheels with the same offset. They confirmed it but told me they found something that could have been very bad for me while driving. They showed me metal clips that fit around the lug bolts up against the hubs. He said those clips should be taken off when going from OEM wheels to after market wheels. They also said several of the lug nuts were only hand tight and it was do to the clips being left on. I have posted a picture of these clips. Does anyone know anything about this? I'm dropping by the shop tomorrow to discuss this with them.
MeanGreen03
TX
Yes, just leave them off. They can cause your wheel to not sit flush against the rotor.
Physh1
Best to remove them BUT it depends on the wheel casting. Some wheels have a relief by the lug hole & that retainer won't affect a thing but wheels with a flat surface mount cannot have those retainers in place.
Cameron
ntxstallion
When I ordered some wheels from tire rack, it warned me about those very clips.
My01yuk
My01yuk
Dallas Tx
Thanks fellas, makes me feel like discount tire wasn't just saying some off the wall shit. Not that I thought they were but just wanted to check with some of you.
chauncey0337
MLT, WA
Does anybody know if these clips will affect the nnbs ltz 20s? Because I still have mine on and don't want to take them off if I don't have to.
bottomline2000
Dallas, TX
Aren't those clips used just for vehicle assembly? Keep the rotors on and centered without wheel nuts?
ntxstallion
Don't think they will hurt since they are still on from the factory. I don't think GM would make a booboo that big. I think for factory rims, they are fine.
Spring Hill, Florida
The clips are put there from the factory so that as the vehicle travels down the line the rotors don't fall off. They are not necessary to have on. when you have your brakes done and replace rotors you will need to have them removed any how.
Steven94
