cowboyzr2
Looks like Firestone Ride-Rite bags.
You should find one of these two fittings screwed into the TOP of the air bags through a hole in the bracket.
The air lines just push into them and lock... It's a pretty good system, actually but over time you'll have small leaks that are real easy to fix. If you find the leak with soapy water, just push in the ring to pull the line out. I'd try making a clean cut and taking off 1/2" or so of the line, then reinserting it. That usually solves the problem.
