I purchased this vehicle in Aug. 2018. Shortly after taking delivery I noticed a slight loss of air on the right front tire. I removed the wheel and checked all possible areas, not leakage found. Thinking there may have been some dirt or other debris in the stem area, I watched and checked same very often. I would bring any loss up to proper PSI. I only had about 1600 miles on the vehicle when I started a trip which required highway speeds. I hadn't been into the trip more than ten miles when my right began losing air quickly. I was able to get off the road and get back to the dealer. They couldn't find a leak until the wheel was submerged and the stem was wiggled. Replacement of the stem solved the immediate problem. I resumed the trip, and about 300 hundred miles into same, the left from began dropping air. I nursed the vehicle back home and made another appointment. The valve stem was changed and I'm back in business.
After numerous conversations with wheel and tire knowledgeable individuals, the general consensus is that the stem is not the correct size. My dealer uses the vin. to determine the proper stem.
This GMC Denali is a Black Edition, special 22" wheels and tires are provided by GMC and they are dealer installed. They are shipped to the dealer, tires on and placed on the vehicle. My guess is, somewhere in the switching out of the wheels, a mistake in stem size has occurred. My interest is finding out if any other owners of a 2018 GMC Yukon Denali Black Edition have experienced this problem. Thank You Dave
