air ride kits?
ILLEGAL REGAL
Tinley Park, IL
in the rear I'm running djm shocks, what was on it before bags and it rides great. I have a ride tech kit, upper mounts are designed to fit in the spring pocket with a stud out of the top then you put a 4" washer and nut on it above the pocket. Easy install.
I didnt measure height but I'd say its around 2-3" and same with the lower mount.
The top mount is excellent, it keeps the bag out of the pocket so it wont rub, the lower mount I think is too tall.
NASTY GM
Nor Cal
I'm running 2600 lbs Conitech in the rear and strut bags in the front for now. When I lay it out I'm sure they will be swapped out with something else.
ILLEGAL REGAL
Tinley Park, IL
Ooops, had to pit the wheels on and put it on the ground with no shocks, bumpstops, or torsion bars as it got late. Wish it will sit this low when done haha
I am here: http://maps.google.com/maps?ll=41.814742,-87.658553
ILLEGAL REGAL
Tinley Park, IL
Got it 90% done, need to install height sensors and do some little work to get the rear down a tad more. Rides like a caddy deville!
Might just look into a lowered a-arm in the front too, but it might bring my ride height down too low
Excuse the filth
waxworkz
Excuse the filth
you're running the ART shockwaves in front right? which models did you get? also, did you completely remove your torsion bars?
ILLEGAL REGAL
Tinley Park, IL
These are the "black" series, they now use a sleeve bag instead of the double convoluted. They're supposed to be a 4" stroke shock but I get 6" of travel.
Yes torsion bars and the crossmember for them I took off too.
jrsmyre
