Amp/Eng whine? Audio guru help(tried it all)
Tahoewhat
Ballin' on a Budget
TX
Ok, i have engine whine. Been searching all over the net for answers and have seen some and did them. The whine isnt terrible, at idle hardly noticeable, get moving and its very noticeable. So, now i figured w/ our vast amount of folks that are very knowledgable w/ audio equipment i would ask here.
Also, this happened when i installed the p4300dvd radio. Before all same equipment, except stock nav radio as the headunit and didnt have any whine or noise at all, only when i changed out the headunit.
I have a RF T400.4 amp. Four channel amp. bought brand new. only had about a year, but could be longer. Headunit, pioneer p4300dvd. RF Rca's. (dont know if shielded, dont know how to tell, got them free)
Here is everything i did, per reading around and just my own little knowledge.
1. Power wire is on drivers side of tahoe
2. All rcas are on passenger side
3. Amp is grounded to seat bolt, paint is stripped all the way down
4. Re did ground, ran wire to battery (temp) just to see
5. Read pioneer is notorious for the pico fuse blowing. (never hot swapped rcas, but tried the grounding the rcas trick, didnt do anything still same noise
6. Took radio completely out, undid all rca's, still noise
7. i know your not suppose to do this, but on the amp i took out one of the rca,s (front or rear one at a time) the whine got even louder, alot louder.
So i ran out of ideas, then remembered i have a JL 300/4 amp. So i undid the RF amp and hooked up the JL amp, NO NOISE. Nothing, not even static.
Noticed the jl amp seems to be better made, the inserts for all pwr/grnd/remote/ speakers is better. You have to really have the wires in it. (if that makes sense) and the front speakers input is on one side of the amp and the rear on the other side.
My question is, have done all this, and the whine went away only when changing out amps, is my Rocksford amp bad somehow? The wires are in the same postition and tried the rf amp again and whine. So now im rocking the JL amp w/o whine, but just want to know whats wrong w/ my RF amp.
Thats all i can think of, is the amp is bad somehow. Is there a ground for the rcas on the amp?
Thanks for any input on this. RF amp works fine, just has a whine. :Handshake:
Rivieraracing
Cmon dog, you gotta stop "whining"!!! ha ha ha!!
J/k!!!! Sounds like you finally found your problem, i was going to text you a few days ago and mention about unplugging all your amps to see if the sound changed or went away!! Must be something wrong or cheap about the RF amp, I just don't know much about those!
By the way, happy birthday hot pants!! :party33:
chip
Tampa
What's the amp bolted to?
Are the power wires close to the signal wires?
Do you have good grounds?
ScottyBoy
Shreveport, La
I have had two amps that did that in the past. Sometimes they just go bad like that. I would just sell that amp on ebay or craigslist.
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Amp isnt technically bolted to anything. Its under my captain 2nd row chair. Screwed down to the plastic covers.
If by signal wire, rcas, no they are on oppostie sides, except for when they attach to the amp. No way around that.
Ground is good i suppose. Looked on here, and alot used the seat bolt. Cleaned real good, sanded it down w/ the dremel.
solder joints in the amp, if you swapped to the JL and it went away....
Sorry but you lost me. Solder joints? what is that?
ha ha. No i didnt find the problem, just got rid of the amp, which i guess if you look at it that way, i did. ha ha. But i dont know honestly. Tried it all. Yeah, thats the one thing i didnt even bother to ask you about, all though i think you should know. lol. its electronic and resistors and such. lol
Thats what im thinking of doing, just selling it, b/c i cant think of what is wrong w/ it.
ds99thoe
Gardner,KS
Bad amp is what is sounds like. If you have no RCA's connected and your amp is still making noise it is something with the amp. Never did much like R/F. I am partial to JL, since i am a dealer for them.
MeanGreen03
TX
I have 2 RF amps (T1500 & T600) and have a whine also. I've done everything to try to get rid of it but to no avail I can't. I wish I had some other amps to try to see if I could be as lucky as you so that it would go away. I'd also like to know about soldering the joints.
chip
Tampa
Do you have speaker wires running near power wires?
Carlos123
