Another 6.2 for 5.3 swap going on.
PatDTN
PatDTN
Awesome. Thanks iamdub. I'll figure this out from what you've told me. I was hoping it was going to be pouring oil in somewhere. :)
Geotrash
Dave
Richmond, VA
Chris' approach is the right way to go for making sure the whole lubrication system is functioning prior to first startup. That said, if all you want to do is prime the pump, this is the simpler process for that:
PatDTN
PatDTN
Geotrash, thanks.
I was just down looking at those oil cooler lines. I'm pretty sure I can do something with those to force oil throughout the engine. Need to spend some time figuring out how but I suspect PVC pipe and air pressure are involved.
kbuskill
NE. FL.
Geotrash, thanks.
Just thinking out loud here... couldn't you also insert a fitting in place of the oil pressure sending unit a the back of the engine and force feed it from up top a lot easier?
donjetman
Disconnect the fuel injection harness(es) or ignition harness(es) and crank it over with the starter until you see oil pressuere. You could also remove the spark plugs too.
smokymtn65
East TN
That's a lot of cranking... Ask how I know. LOL
PatDTN
PatDTN
Yeah, this oil pump has a lot of open space in it ti fill. I don't think I'm comfortable with that method. I'll do it after I get it pumping some oil though.
I got my valve stem seals last night as well as my cool valve spring tool. Unfortunately I was called out to a brush fire and was hauling butt out of the house when I saw the packages on my porch. Too worn out when I got home.
This morning I'm popping the old springs and seals out, giving the valves a quick inspection, popping in New seals and new springs, and dropping the heads back on. Pictures to come soon. This valve spring tool is awesome.
PatDTN
PatDTN
Funny. Doing this write-up is more work than changing the springs and seals. Here we go.
Head on my bench ready. (I actually already did the first cylinder.)
First I screw down that plate finger tight so it'll move around pretty easily.
Then add the part that presses the valve springs and the bolt. I did some reading and a lot of folks stripped/galled the tension bolt so it's coated with anti seize. You want to wiggle things around so the tension bolt is centered between the valve springs and the plate is centered onto the caps. Then tighten down the mount part.
As I started compressing the first one I realized it was a little tight. I tapped the caps just lightly and the keepers popped loose. Then I finished cranking down the tension nut to get the keepers out. On the first couple I would run the tension bolt well down through the tool then turn the nut on the shaft with my ratchet box. I figured out they gave me a couple extra nuts and a lock washer so I figured out where I wanted it and double nutted the tension tool so I just turned it from the top of the bolt. Did I mention all this goes VERY easily?
Keepers off. Ready to unload the springs and pull those and the seals.
Seals exposed and ready to pop out. If I was worried about slipping and scoring the valve stem I could slide them out at this point since I'm on the bench. Note the tool base is still there.
Seals off and the area wiped down some.
Fel-Pro includes these cute little straws to slip over the valve stem to keep the keeper groove from cutting the new seals. I added a tiny wipe of assembly lube on the top before putting the seals on. With the seals in place and pushed down I found a 15/16" deep well socket was just the ticket for snapping the in place. Just a tap with the heal of my hand did it.
This is the tool I used. It has just enough flexibility to let me easily put the new springs in and center things up so the keepers drop in place.
Betsy2004
