Antifreeze leaking with no overheating
skidmrk
It's hard to see, but look at the block right under your water pump. Common for the gaskets to start leaking or the pump itself to start weeping. Just did a water pump and ac compressor replacement in our '03 z71. Started as a slow leak, progressively got worse and would only leak once shut off and cooled down a bit.
R
rn4l21
Ended up being the water pump. Thanks for the help guys. I appreciate it.
98yu4x4
‘01 Tahoe, 207K miles - The low coolant light came on so I let it sit while I ran and got some. Came back to this leak. No check engine light and no overheating. Any ideas what to check first?6772b415e9e556bdc9c880d3563d1e26.jpg
My 97 Yukon is doing the same thing but only when I'm park on an incline which happens to be my driveway.
certa
