Any way to make the fog lights stay on?
911jason
Simi Valley, CA (LA)
I've never had a car where I had to turn on the fog lights every time I drove it. Is there any way to just have them turn on whenever the lights turn on? I'm really hoping I'm just missing some simple thing...
Migo713
Houston
I just wired my headlights with the fog lights together using a relay, so every time the headlights come on at night it triggers the relay on and powering on my headlight and fog lights together. So the fog light switch is not used anymore, I just wired it to turn on my halos and some red led's in the front when ever I want since they're not so important to me.
Migo713
Houston
You will need a 30/40 Amp relay and some 12 AWG wire or 10 AWG, some ring terminals and some butt connectors or solder and iron/ tape. Basically you will use 4 terminals on the relay.
Terminal 30 will be hooked to the battery Positive, you can add a 30/40 amp fuse inline.
Terminal 85 Will be hooked to the battery Ground or any good Chassis ground
Terminal 86 is the turn on wire. This will be coming from your headlight bulb 2 pin pigtail. I usually use the driver side, Turn your headlights on and meter both wires with a DMM. The one that gives you 12v when your headlights are on is your wire.
Terminal 87 is your 12v output to your headlights and fog lights. You will wire 4 wires out of here one for each to turn on.
---------- Post added at 11:51 AM ---------- Previous post was at 11:47 AM ----------
Then all you need is to ground each bulb using the factory 2 pin pigtails in the truck. Meter the wires and use the ground wire on each or you can ground separately to any good chassis ground, but this is easier.
---------- Post added at 11:56 AM ---------- Previous post was at 11:51 AM ----------
Its easier if you are installing HID Kits to the headlights and fog lights since they come with female pigtail harnesses to use. Other than that you will have to splice and tap in for the grounds and maybe cut the positive wire in the pigtails to separate the signal. I would look to get some female pigtail harnesses so you don't cut any of the original wiring.
Migo713
Houston
Heres some pics in a small scale
RedneckLimo88
