Anybody tried running these Sway Bar End Links?
01Konvict
Boats n Hoes
Raleigh/SML
Don't think anyone has tried them but it would be the perfect setup for the front sway bar fix after lift keys! Order a set and install them!
These paired with jounce stop extensions and rear jeep sway links are all the right parts when doing a key/spacer lift.
ATIII
ATIII
Brighton, CO (Denver)
I
So I just got these from the UPS today and the bolt on the Clevis and the one that goes through the sway bar is slightly to too big. It's not by much I could prolly force it through with a hammer close but I'm wondering if I'm going to degrade my LCA by drilling it out a bit to accommodate the bolts.
Any advise?
The links are a BIG IMPROVEMENT as far as quality and build. They're not just a bolt, some washers and a spacer like the originals that I seem to break with ease.
AppocAlexx
Darth Appocalexx
Abilene TX
Looks like a good deal, may have to look into ordering some after I get my lift installed. Good find. Look forward to seeing some installed pics. They look beefy and strong too.
ATIII
ATIII
Well here ya go, they don't work with the Clevis mounted on the LCA, but they work just fine inverted. I'll post after I put some miles on them, but DAMN these things are beefy!
01Konvict
Boats n Hoes
Raleigh/SML
They look great installed!!! Well done! But damn you got some killer angles and need UCAs. How does it feel now?
ATIII
ATIII
It rides as good a can be expected. Not rough by any means but definitely stiff. The links seem be doing well haven't heard any clunks or strange noises since putting them in. Gonna prolly get on it hard today to give em a run and see if they helped with my rubbing issue on the LF tire in reverse.
frankenstien
Fairbanks, Alaska
I have a set of these on my 2500hd, they work great, ill grab a pic of mine, im pretty sure you have the clevis turned 90 degrees off.....not trying to be a D#$%, just saying....
Champ74
