anyone do E-fans on a obs??
Status
Not open for further replies.
sparg93
Expedition Tahoe
NJ
if you're having a tough time with wiring, I would personally just buy a kit....that's what I did.
They have a lot of one speed setups out there and it will come with all the parts necessary. The ones with the probes that slide in between the radiator blades are the cheapest and easiest to install.
You may have mentioned this prior, but what is your alternator rated at??
Monstar_est87
City of Angeles
Yea I just gotta find sumthing more reliable... Any suggestions..? And im not sure about my alt the limited rocks the police package so I assume its on the beefy side...
sparg93
Expedition Tahoe
NJ
Then you probably have the 140a alt - if so, you're ok!!
http://cgi.ebay.com/ebaymotors/60-A...469730?pt=Car_Audio_Video&hash=item5d2e0b95e2
You must get a 60amp relay kit. This kit above has a temp sensor, so as soon as the temp is reached, it automatically triggers ONE speed on your fan (personally, wire in LOW speed...you will not need high and high will draw more power)
Also, you will need to splice a fuse in prior to this relay...get a fuse rated at 50amps so it protects the relay.
You could tap the temp sensor into an existing location on your block OR you can buy that pipe i listed earlier and splice it between your upper radiator hose (i also recommend buying a new hose)
If this sounds confusing, check out the company I posted earlier. I had the owner build me my electrical setup exactly as I wanted...it came with instructions and everything I needed.
ezdaar
Chat Troll
Redneck central, Aka Houston
thats cool, lil kit..
Temp is abit low tho.
Still woud wire up high on its on temp sensor to come on at 210 to try and save motor from extlreme overheat.
Monstar_est87
City of Angeles
Sweet... Thanx again spurge... Ill look at the controller again & see wat I can come up with...
Ezdaar- how did u wire up the high..? & again sorry bout sunday helped my uncle move after a graveyard shift and I was out...
Atomic- u gotta part #..?
sparg93
Expedition Tahoe
NJ
you will have three wires coming off the fan, the color of wire changes depending on yr of vehicle it came from.
Easy way to test - take the ground wire on the fan and ground it, then take the remaining two wires and one at a time, touch the positive on your battery. You will be able to feel the difference between the two speeds.
My recommendation is still to start will LOW speed; my high speed never came close to kicking on. If it turns out you do overheat on low, then simply rewire and switch to high....but if you don't need high, there is no benefit to running it and the deteriment is higher load on your battery and extra wear on the fan motor.
Monstar_est87
City of Angeles
Damn sunlit I gotta get sumthin less complicated I gotta get sumthin way simpler cuz im retarded like that... Haha...
Sparg- yea im just running the low that high is really powerful... Im gonna look in2 that ebay 60 amp...
qukon 95
u will need the high spd if u use the AC and to make it simple & cheap get the volvo
2 spd relay and efan at the jnk yrd we will talk u through it to wire it. L 2 R my shroud i had
to notch for it to fit over the resistor harness, that after trimming EFAN shroud and mounted,
the mount i made 4 the relays theres 1 in back and another 1 on the side of the volvo relay,
(after i took pics) and that bag beening sucked and it's on low.
Status
Dave6137
