Anyone experience this??
Enem178
North Jerzee
I'm coming over from another forum and hopefully this forum gets more traffic. Anyway, I have a almost squealing like noise when ever I make left hand turns. Its worst if the street is bumpy. It almost sounds like tire squeal but it only happens on left hand turns and the sound actually changes pitch as I travel over the bumps. The sound is coming from the drivers side front wheel. Any ideas?
Effeckt
Resident Cards Fan
Phoenix, AZ
:welcome: This forum certainly gets a fair amount of traffic. Sounds to me like a power steering issue. May be simply that your low on power steering fluid. I would try filling up the power steering pump first and if you still have the issue have the pump looked at.
latinyukonrider
Moore, OK
hey i was goin ask new to the forum but i put an eibach lowering kit on my 05 yukon but the front lowered but the rear did not and im just wondering why the rear did not lowerer and what i can do to lower it thank you
Enem178
Enem178
North Jerzee
WOW!! Im not used to the rapid response!!! Ill will definitely double check my fluid. I should also say that when i'm making the turn, the wheels aren't at full lock. Also it dosent make the sound when the truck is stationary. Again thanks for the quick reply!!
Effeckt
Resident Cards Fan
Phoenix, AZ
Welcome to the forum too Latin. I would post this in a suspension subforum for the 2000-2006 body style and you'll get a lot more responses.
Enem- no problem! Happy to help. I hope that's as simple as it is for you. I am not an expert by any means though.
Enem178
Enem178
North Jerzee
Yeah effeckt, I hope its a simple fix too, Im going to check the bearing when I get a chance also
Tommy walton
