Anyone running Spohn Rear Control Arms?
Byoung1330
Cookeville tn
That’s not a bad price. I wast 100% on the price I seen some on eBay a while back an thought they was around the price I said
67RS427
Shop around a bit, you'd be surprised... This place below I had bookmarked for years, I just saw they have them listed even cheaper. I remember talking to them and they use a different caliper in the rear (size of pistons) to better bias the brakes to compensate for the 16" front. I can certainly confirm that they stop this heavy truck really really well. It's so much better than stock or the power stop rotors/pads I had on before. It's insane TBH
https://www.littleshopmfg.com/gm-99-18-silverado-sierra-1500-front-16-tc6-big-brake-kit/
Looks pretty sick too
I’ve had them on for couple years. Never had a issue. Thanks tho. An I’m sure they do hold some heat in but I’ll take it for the look. I do want a set of Wilwood but that’s bout 5 grand
More like $3500 but it’s still a lot. I have them on both my trucks, the 16”/14.25” kits are what I got.
signguy62
NJ
Reviving an old thread.....
Would the Spohn boxed, non adjustable lower arms with poly bushings, work with the DJM trailing arm relocation brackets?
The DJM brackets would center the tires in the wheel wells and the Spohn arms would give you the added beef for less flex and wheel hop.
That is, if they would even work together.
Doug118
The djm brackets don’t center the axle. They just drop the back of the arm down to get a better angle for better handling and ride quality
you need a adjustable panhard bar to center the axle, I have the spohn boxed arms but stock height
I think he meant centering it fore and aft, not side-to-side. I'm sure you guys already know this: On larger drops that have the arms north of parallel with the ground, the axle is moved forward due to the arc of the arms. It's minimal, but noticeable if you study it hard enough.
signguy62
NJ
Panhard centers left to right. I have Spohns adjustable for that. The DJM trailing arm relocation brackets are for moving the axle back, in drops greater than 3in. Was just wondering if the beefier Spohn arms would work with the DJM kit.
But thanks anyway!
piranha4201
