And it still threw codes? I wonder if all the Granatellis are like that or did they just have an issue you with yours. Not sure about now, but back in the day, Granatelli was reutable. Lots of high-po parts.and the Granatelli is a OEM sensor that they cut open and modify in some manner then suture it back together it isn't there own creation
I don't know I went online at the time and read about the Granatelli's (a lot) and it seems to be a pretty common thing, lots of reports of there MAF throwing codes, this was on the nbs mind you, I was considering maybe getting one for the nnbs since it's a completely different design but just ran into more comments of them throwing codes as well on the new design so I just haven't pursued it decided to swap the throttle body and thought about maybe getting high energy coil packs etc, but dam there not cheap I would have to like buy a couple then buy a couple next month or something till I eventually ended up with 8And it still threw codes? I wonder if all the Granatellis are like that or did they just have an issue you with yours. Not sure about now, but back in the day, Granatelli was reutable. Lots of high-po parts.
