AT tires for 2015+ to replace 20" Conti's...Recommendations?
Dlayne
Bend, OR
Had a set of 275/60/20’s for my winter tires on my ‘07 and ‘17. Pretty tight and that is with a front level kit on both. The tires were studded so regular tires should be fine. Both also had retractable running boards. That is where it was close.
@tmarzetta You keep posting that tire set-up and I am sending you the bill:)
tmarzetta
LMAO :D
DenaliBQ
do you have pictures i would like to see
Dlayne
Bend, OR
Looks nice. Would love to see a shot of the ‘17 straight on the side to see how close it gets to the step. I have mudflaps so that’s a concern. Thanks!!!
Unfortunately, I had to replace the tires this winter and the studless I went with only came in the 275/55/20 otherwise, I would throw one on for a pic. I like the look of the bigger tire. I can tell you that it was close (1/4”) or less from the inner most part of the step. The radius is 16.5” vs. 16.0” plus I had another 1/8” for the studs. The steps are recessed about 6” into the wheel well so your mud flaps might be of a concern if the go back further.
A good test might be to see what your tightest clearance is and if it is more than 1/2” you should be good. Double check manufacturer details of the tire though.
Do you have mud flaps with retractable steps? If so I would be very interested in what flaps you found to work and a pic. I haven’t found any that work. Just 3M’d the whole damn lower rocker panels. They cinder the roads in winter here. Hell on vehicles.
Hope that helps some.
C
cardude2000
Thanks. I’ll have to check. Here are the flaps.
Husky Liners 58201 Black Custom Front Mud Guard https://www.amazon.com/dp/B00MFSR6Q6?ref=yo_pop_ma_swf
I also have Xpel ultimate on lower panels and front quarter panels.
Daddyyukon92
