Automatic liftgate open/close not working
Dre Robb
I recently experienced my lift gate on my 2009 Tahoe LTZ. I hear it the motor releasing and the gate begins to lift and then snatches back and locks. Is it a sensor or the struts as mention above. I need to pack somethings for a road trip in two weeks so I want to get this fixed before then. Any suggestions?
fiatdale
Houstons Best
Houston
If you dont worry about the power lift, and hit the button to release it to manually open - youll be able to see if its the struts which it most likely is. If you lift it open and its heavy as all hell - its the struts.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Mine is currently not working. This is frustrating. It has been working fine and now when I press either button it wont work. It unlatches but wont power open.
George B
¯\_(ツ)_/¯
Yup. Just doesn’t power open/close with the fob, overhead or rear button. Too cold to goof around with my tech2 and see if it’s disabled due to temperature.
No love from it today. Had my shop at 50-ish and it still wont power open or close. Tech2 said it was out of range at first and then said it was not out of range. Had a code too.
5A2A1673-C5F2-4608-A3A9-78A3D5DAC234.jpeg EAE9F941-B596-418D-934D-C7E91E1D6500.jpeg
George B
¯\_(ツ)_/¯
I found the parent thread for this issue but no real troubleshooting outline. The just of the thread is if it tries to open and can’t it’s the struts and if it doesn’t even try or makes a bunch of noise by the latch and then fails its the latch.
In other words “just chuck parts at it”. LOL!
Sounds like it will need to be 13584872 if that sounds right @915_Tahoe ???
wjburken
Eastern Iowa
If the latch is working for manual operation, I don’t think that is the issue, as it needs to release either way. I’m assuming the liftgate stays up when you open it manually, so the gas struts are probably fine. With the lift gate open, can you confirm that the lifting bar is still attached to the liftgate motor? You should be able to open the rubber seal in the driver side and look down where it attaches. If it is attached, you might have an issue with very thick/cold grease in the gear box casing issues.
Enrique01
