Autoride bypass
okfoz
54 looks like the compressor pump for the rear auto level.
I am pretty sure just pulling the fuse will not make the "service suspension" go away. Otherwise there would be no use for the resistors, and this conversation. It might work on some cars, but in this case I do not think si.
dubyagee01
My fuse was pulled and had no warning. I replaced the shocks, put the resistors in place and replaced the fuse. The warning showed. I was trying to fix the leveling compressor but with further study realized its a stand alone system. Im going to pull the fuse and see if the warning stops.
okfoz
The leveling system will give you that message.
STUPIDDR
Yes you need resistors for all of them. It sucks trying to make it work but it'll be worth not to have the service suspension message
JT 07LTZ
Would you mind sharing if the resistors you used for the ride height sensors were the same as those used for the shocks?
Also there are 3 wires to each of the ride height sensors which 2 wires is the resistor wired between.
Thanks!
CdnDenali
JT 07LTZ
Thanks!
Your substituting the shocks with the resistors, not the ride height sensors. The shocks have a 2 wire connector, cuts and splice. Doesnt matter which end is connected to the resistor.
dubyagee01
Me too. I think the compressor not working is tripping mine as said above.
STUPIDDR
I understand and have done so for the shocks, but still get the dic message because I disconneted/removed the ride height sensors.
JT 07LTZ said you needed the resistors as well when removing the ride height sensors specifically which is why I'm asking.
bruh2125
