Going to check this out. The height sensors can be reached if I stick my hand under there?
And should I replace the 3 fuses for the hell of it since it is cheap?
---------- Post added at 10:09 PM ---------- Previous post was at 08:40 PM ----------
---------- Post added at 10:10 PM ---------- Previous post was at 10:09 PM ----------
Well, I found the height sensors. I broke part of the plastic fender cover in the process, but thats what you get when you work in the dark and in cold weather. I couldn't move them, because I assume I would have to disassemble the rods? Should I spray with WD-40 and leave it overnight in case a sensor is stuck?
BTW- I thought the compressor always kicks on no matter what when you first start the truck. If mine isn't, does that tell us anything?
