Okay, so I changed the front shocks this past weekend (rear and compressor last weekend). Followed the Avalanche DIY someone posted on a previous thread about changing the shocks all around with air ride (Awesome DIY BTW). My suspension works like new on the highway. Smooth sailing. But I am getting some "clunking" noise at low speed when I go over a pot hole or even a crack in the driveway where there may be a 2" drop from one surface to the other. It is almost like something is loose and bottoming out before the shock kicks in. I was careful to make sure the top plate, spring, and shock were lined up prior to reinstalling and the two top plate bolts were tight prior to relieving spring compression. I'm not sure what else it can be. Ball joints are in good shape so I don't think that is it either. Please help! Any thoughts would be greatly appreciated!!!
Side note...I'm also getting a little clunking noise when I turn the wheel sharp, like when parking in tight places. Visually the stabilizer bar link ends and stabilizer bar bushings are in good shape. Could these still be the culprit?
