- Joined
- Jun 9, 2009
- Posts
- 8,744
- Reaction score
- 607
xjayx. I have welded the links to the upper arms from a oem set up not hard at all. What i do is put the truck on jackstanks and measure wher the oem mount is. then i put the adjustable a arms on and get them to where i want rear end to sit and mark on them where the mount should go. Cut of the mount off oem set up and then weld it onto new spohn arm and pop the link on and your good to go.
i set the rear end up at a -2 degree angle so when you get on it it will be at 0
