Back up light bulb
Dr. Overkill
El Cajon, CA
Gang,
Had a backup light go out. Pulled it out, says it's a 3057. Strange, that's a 2-filament bulb...
So I picked up another 3057, and everything's good now.
But after getting home, I checked online and at least a couple sites (Osram Sylv and Phillips) show that OEM spec calls for a 3156, which is a single filament bulb as I'd expect.
I wonder if I may have replaced the bulb once before with an incorrect one or if maybe some of these came from the factory with a 3057 for whatever reason (maybe they were out of 3156s that day)?
Any idea? Doesn't seem to be hurting anything, but if the filament that's used in this 3057 puts out less lumens than a 3156, I just threw a little money away...
blueflamed03
Oklahoma
shows 3057??
1997 CHEVROLET Suburban/Tahoe (With halogen capsule headlamps)
Low beam headlamp
9006
9006SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9006ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9006EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9006XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9006CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
High beam headlamp
9005
9005SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9005ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9005EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9005XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9005CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
2357A
2357ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
2357A
Rear turn signal
3057
3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
3057
Stop light
3057
High mount stop light
Assembly
Fog/Driving light
H3-55W
License plate
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
3156
3156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
194
Rear sidemarker
194
Ash tray
194
Glove box
194
Map light
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
211-2
211-2LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
211-2
Step/Courtesy light
168
194
74
74LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Under hood light
89
89LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
161
161LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
194
74
Check engine indicator
74
Hi-beam indicator
74
Seat belt indicator
74
Brake warning
74
Automatic transmission indicator
161
Directional signal indicator
74
D
Dr. Overkill
El Cajon, CA
Exactly. My hoe had a 3057 in the backup light. According to the above, it should have been a 3156:
Back up light
3156
blueflamed03
Oklahoma
ahh, sorry mis-read...sounds like at one time someone used a 3057 as a quick fix maybe?
D
Dr. Overkill
El Cajon, CA
I'm the first and only owner, so I'd have no one ta blame but myself :D But I'm usually pretty **** about replacing that kind of stuff with like items, so that's why it struck me as odd.
---------- Post added at 04:05 PM ---------- Previous post was at 04:04 PM ----------
BTW, love your paint! *drool*
ScottyBoy
Shreveport, La
A 3156 is a 27 watt bulb. A 3057 is a dual filament bulb, and the brighter filament is usually about 26 or 27 watts. So its basically the same bulb, but with an extra filament that will never get used. So its quite possible that the factory suffed a 3057 in there if they ran out of 3156 bulbs. They put the 3057 in the tail/brake lights so I'm sure they had plenty of them around.
Radioflyer
it's worth noting there is a 50w halogen bulb with the 1100 series or 3000 series base. Had that in my 97 silve and will soon put it in the 98 tahoe.
D
Dr. Overkill
El Cajon, CA
Nice! That doesn't get too hot in there if the lights on for more than a few seconds? I've read about some putting an LED cluster in the back up light slot but I've also read a lot of disappointing results from LEDs so I haven't bothered checking into it.
Radioflyer
It's true. LED "bulbs" simply do not have enough output to compare with incandecent or halogen bulbs. LED bulbs work best when used in an Array or specialized reflector.
sallimoservice
