blanchard7684
Senior Member
- Joined
- Dec 23, 2024
- Posts
- 251
- Reaction score
- 135
Here is the quote you want. Post 167.You do realize that if you put the same quantity of air in two different volume cylinders, the pressures will be different right?
For a given set amount of air ,,,, say that amount of air needed to perfectly burn a given amount of fuel at stoichiometric ratio, if you put that amount of air in a smaller engine then;
But if you take that same amount of air (the amount needed to burn a given amount of fuel at stochiometric), and put it in a larger engine, then you get;
Maybe I should have mentioned this earlier, but I just kinda assumed this was a common sense thing.
So burning the same amount of fuel, at the same afr (which requires the same amount of air) in two different displacements engines makes the same power ( assuming the engine efficiencies are the same of course).
That lecture you keep referring to even alludes to that later on when talking about ways to raise power, see Pressure (adding boost) at BDC statement below.
I think that maybe you've not be seeing the forest for the trees and focusing on just the equation as symbols, and not what the equation is actually doing/ telling you. Which happens even in the adult / professional world every now and then.
This example literally says that by Boyle's law, lower displacement raises Pbdc which can make same power as a higher displacement with lower Pbdc-- if everything else is the same.
So if I increase Pbdc, by reducing displacement, I get more power. This is justified by Boyle's law. So if I keep reducing displacement, I keep getting more power.
I'm not walking through this absurdity again.
This is why I'm mocking you.
You have beclowned yourself.
I'm seeing if I can model a cylinder in a program that is 0.25" to see what kind of insane power I get.
