BAMF Pri's 2005 Chevrolet Tahoe build thread
05Single
afraid of the dark
Well Christmas has come and gone and truck has some new parts for it.
New parts list:
Speed Engineering 1 2/4 headers to y pipe.
Escalade roof rack
Escalade third brake light
Escalade rear vents/appliques
3" lift keys
Tailgate light strip
As of right now parts are getting color matched and threw the tailgate strip on.
32608170778_81d8efe495_b.jpg20181226_221357 by James Pate, on Flickr
45567611355_d4c7f308f7_b.jpg20181226_221422 by James Pate, on Flickr
Nice. I had one of these tailgate strips on for a bit , looked good but I didnt have led tails so it didn't really match. Now I have led tails I ordered another one(actually 2 styles to try out) .
But imo for yours it might be too much if you add the esky 3rd too
73impala
73impala
Margate, FL
Yeah I am 50/50 on the esky third but we shall see when it comes back from paint.
Also cut up an HD grille that I had laying around to get color matched and then a billet grille.
45850216555_c29531bb98_b.jpg2019-01-16_10-33-10 by James Pate, on Flickr
73impala
73impala
Margate, FL
Well ended up buying a Engine Coolant Temperature Sensor to hopefully fix the hard start. Seems to only have the issue when the ruck is driven then started through out the day. I guess from there if that doesn't fix it then I guess onto the MAF.
Also talking to someone who has a cheap rancho 4 inch lift for sale that I am interested in for the lift spindles so that way I can run them with 4wd hubs and lift spindles.
05Single
afraid of the dark
Give some people in here heart attacks with this pic lol. I have mine cut out for a project too. Is it necessary to cut for the billet grille ?
73impala
73impala
Margate, FL
Well changed the ECT sensor and doesn't seem to have fix the hard start. Next is to try cleaning the MAF before I replace it. Started working on adding some led lights to the under carriage. Pics were from last weekend, I added some to the wheel wells today so all that's left is the front and rear and probably under the middle somewhere.
31861916437_07900d21b4_b.jpg20190113_182124 by James Pate, on Flickr
31861915677_cfa365e788_b.jpg20190113_181930 by James Pate, on Flickr
73impala
73impala
Margate, FL
Lol I like the lights to show off the powder and eventually chrome.
But I used 15w eagle eye leds that I found on amazon.
They are the screw with a nut style so under the doors there are 4 holes in the metal that folds under the body I mounted them there. Then the wheel wells I took the fender liners out and drilled holes into them and mounted three of them there. The front and rear I will probably end up using the three 9w pods like I did on my truck.
MIXC-TRENDS-4Pcs-9W-Under-body-led-Rock-Lamp-Under-LED-Car-Chassis-Decorative-light-Waterproof.jpg
I am running the wires from the front driver wheel well down the driver side around the rear then up the passenger side to the front and probably some in the grille. Then going to put a switch in the upper cubby hole in the center console and run it directly to the battery.
All finished it should have 26-30 led pods under it.
Here is with the wheel wells. Got to order the pods for the front and rear. Also want to add more in the center so there's no shadow.
46816770421_58538b4fdb_b.jpg20190120_001819 by James Pate, on Flickr
46816768941_aab98af69e_b.jpg20190120_001926 by James Pate, on Flickr
46091745884_0028a106f9_b.jpg20190120_001847 by James Pate, on Flickr
46091745804_4b662f326a_b.jpg20190120_001901 by James Pate, on Flickr
And a picture of mine with them as well. Mine has 26 I believe.
31861912687_e5f178db81_b.jpgimagejpeg_3 by James Pate, on Flickr
Waiting_to_Dye
