I'm also having an issue with the driver's side blend door for the a/c, its only allowing hot air through and the passenger's side heated seat doesn't work anymore.
Once you're sure this electrical problem is out of the way, the other two issues are not too expensive if you do it yourself. The best tool you can own Jason is a Tech2 when working on these trucks. The Tech2 may allow the door to reset or you can use the tool to force it back into position if the motor is still working. At the least, it will tell you which one is not working and why it failed. Many times, issues with heated seats are fixed with a soldering iron and don't cost any $$, just time.
