BATTERY - Deep Cycle Recommendations
13UpInSmoke
Running a yellow top Optima in my rig right now, did have to return & get a new one after about 6 months as it failed at holding a charge but 3 year warranty?! Have had some success with Odyssey as well but a little more expensive than Optima
M
Meccanoble
Georgia
i thought optima had the lower warranty and red had higher warranty? I used to have a yellow optima but was told batteries like DieHard gave a better value. Appreciate the feedback, will compare prices.
petethepug
Michael
SoCal
Since I discontinued using Optima batteries after almost two decades I switched to Bosch's AGM made by East PEnn / DEKA. Bosch ended their licensing agreement with Pep Boy's. They rebranded their AGM as Champion AGM, like the spark plug company. Johnson Control makes the Champion AGM batteries :) .
All four of my vehicles now run Champion AGM batteries made by Johnson Control who manufacture Optima batteries. HA! I found the biggest AGM battery for our power hungry Esky which is the H7-850CHAGM. It barely fits in the tray and kisses the overflow tank but for 1000 Cranking amps @ 32* and 850 CCA with a 4 year no hassle over the counter warranty, you cant beat it. When they go on sale expect to pay about $170.
The 07-14 have smart charging systems. They'll properly maintain an AGM battery including battery sulfation mode that determines the correct charge protocol to correct plate sulfation condition.
Here's what I have in the Esky. Purchase it over the counter from Pep Boy's if you decide on this one. They closed all their retail part stores and only have service bays now. If you want an AGM with a little less performance but made by DEKA, Sam's Club sells Duracell AGM for a little less with a 3 year over the counter warranty.
M
Meccanoble
Georgia
Thanks! I was looking at the H6 version which has slightly lower specs but if the H7 will fit without modification, thats the way I'm going. Someone mentioned JC being a brand sold at Walmart.
Specs of H6
Height (in.)7.5
Cranking Amps @ 32F950
Terminal TypeA1
Width (in.)6.94
Reserve Capacity (minutes)120
Length (in.)11
Voltage12
Group SizeH6
BCI #48
Weight (lbs)47
Height (mm)190
Length (mm)279
Right Or Left Hand PositiveRight
Cold Cranking Amps (CCA) @ 0F760
Width (mm)176
Wet or DryWet
Tonyv__
Bucks county PA
My yellow top optima is going on 5 or 6 years of heavy use, between audio, electronics, air compressors, and power inverters. Has been a really good battery BUT I read a lot that they aren’t as good as they used to be. Unsure if I bought mine before or after they started being made poorly.
M
Meccanoble
Georgia
I heard the same but that was around the time I bought my Die Hard which was about 6 years ago. Just came from Advanced Auto and confirmed all is good except my CCA is low, down to 209. Definitely grabbing a battery tomorrow. Debating between the
https://shop.advanceautoparts.com/p...9-P?navigationPath=L1*14920|L2*15000|L3*15597
and
https://www.pepboys.com/champion-agm-battery-group-size-h7/product/2071662
leaning towards the Champion since it has similar features to my current die hard but the DieHard is cheaper and I can get it today...
M
Meccanoble
Georgia
After further research and a good night sleep, I decided to stay with what has done me good and go with the DieHard Platinum. I wanted the higher feature Champion but the DieHard seems to provide same specs as the previous DieHard Advanced Gold battery did. If I can get same life as I did before, it seems like a win.
https://www.amazon.ca/DieHard-02838228-38228-Advanced-Battery/dp/B0777768HP
DieHard Platinum
M
Meccanoble
Georgia
Grabbed the DieHard Platinum. I was tempted to grab the H7 version for same price and has higher CCA and all but I was too scared of fitment so I punked out lol
AceDawg
