Battery Voltage Fluctuation
2001 TX Tahoe
2016 GMC Yukon XL SLT. Relatively new Odyssey battery. I noticed on a road trip this summer the voltage gauge fluctuating while highway driving. Sometimes it would be centered on 14V, but it was often dropping down into what looked like the 11-12 range. I didn't notice any issues that might be related to low voltage other than my 12V fridge in the rear, which was plugged into the 12V plug in the rear, was beeping due to low voltage and showed voltage that varied between 10.5 and 12.5.
B-train
They are programmed to cycle on and off to help with fuel economy. If you need more reserve, you can add an additional battery in parallel. There's a mount already in the truck for it behind the drivers headlight
2001 TX Tahoe
Got it, thank you!
HomeMadeSin
This piqued my curiosity also. Took the first long trip (‘18 XL Denali 6.2 4x4). Voltage fluctuated from a touch over 14v to about 12.5V. Glad to hear it’s by design.
But let me say that whomever was responsible for using 9v, 14v and 19v as markers spread over 8 graphically equal divisions…well hopefully “the fleas of a thousand camels invades his/her crotch.”
z
z
"Whomever" wanted you to not expect the gauge to be accurate. ;)
HomeMadeSin
A more rational nemesis would’ve used ‘L’ and ‘H’ and called it good.
Biscuit mobile
I've had my Yukon since 08/24 and the voltage has always sat on 14. Then I had the issue of a dead battery after sitting for 3-4 hours.This turned out to be the Instrument panel cluster IPC. It was keeping half the truck awake and drawing 7.35 amps. Dealer replaced and programed the ISP and the gauge will sit on 14v for 15-20 minutes and then drop to what seems to be the 12v mark. If I turn the lights and AC on high it will come up some but I'm sure it's charging fine and just going into some fuel sipper mode. The Denali has the 6.2 Ltr and the fuel computer is always saying last 50 miles avg is around 21mpg so I don't care what the voltage says. 70 mph on I-75 I dropped in behind a semi and it went to V4 mode and 33 mpg. Again, I don't care what the voltage says. I'm hand calculating this tank to see if the mpg gauge is like the volt meter.
CoyotesRUS
