Beals build thread
BealT1
BealT1
Was in the Panhandle this summer and thru Fort Waltobn as well.
That 18 should be some big bass and fill that Tahoe well.
Yeah not too hard to pull apart, just sequential.
Bumper cap is all plastic tabs that push thru the bumper but need to be pushed thru from underneath first so that they don't rip off.
Then the lower valance which has a series of pins that pull the center out and then the whole pin pulls out releasing it from the bumper. Fog lights best to come off first. Then the bumper which is all bolts and pulls off.
Rear bumper pads have the same tabs as front bumper cap and then the bumper is bolted on and pulls off.
Not too bad.
Sounds simple enough, I'm not going to want to drive it with bumpers off, it's going to look so goofy haha but it will look so nice afterwards.
As for the 18 it should be plenty of bass. The goal is sound quality and I want it to hit low 20s. I'm still trying to figure out how to get past the bose system. I've come across a couple threads using a line output converter and tapping into the stock sub. I'd like to keep the stock head unit and eventually bypass the whole bose amp and use an amp for the doors. Maybe use a signal processor? I'm not sure yet.
Fosscore
Audio is not my strong point. There are some really good audio guys on here that can definitively point you in the right direction especially with the Bose system which I do not have.
Keep digging. Threads on this subject come up often.
BealT1
BealT1
Lucky you for not having bose haha, if I can't find it on here I'm sure I can tinker with it until I find something that works. I appreciate all your advice.
05Single
afraid of the dark
Hey thanks! I don't know about the cleanest on the forum but I appreciate it. any pictures of yours?
There's a few in here lol
http://www.tahoeyukonforum.com/threads/05singles-virgin-build-thread-03-tahoe.79987/
I have the bose (more of a pita than its worth) but either way i wanted a deck with bluetooth, aux and usb inputs along with different options and settings, like mainly a more defined equalizer and including sub levels for my L7.
But i can't wait till I get a complete system with door speakers and rip all that bose out.
Next on my list will be exterior paint also. waiting till after the holidays , then realized I'm going on vacation in January so won't be till after that. I'll be doing bumpers and grille , exc body parts in early spring.
And as far as mechanics on these , they are the easiest compared to other trucks of its time. your hardbody was easy but so are these , as like Fosscore said most are sequential and instead of bolts and screws like your nissan they're all plastic clips and push pins lol.
Good luck and we're all here to help as much as we can :cheers:
05Single
afraid of the dark
And I always bug @massivespl for audio questions.
He might have more info on what you're trying to do. I just researched what I wanted to do, didn't look at other options. but the only option I do recall seeing over and over again is the line output converter spliced into the the stock sub like you said.
You would be surprised tho, adding a aftermarket deck to the stock bose is night and day in sound quality and power added. I didn't add a sub to mine for the longest time cause it sounded amazing with just my pioneer and the bose. part of it I'll admit it's because the bose was barely broken in, I bought my tahoe off an old man who was the original owner and all he listened to was George Jones at low levels with the bass off lmao. so my speakers were like brand new.
BealT1
BealT1
I kind of feel like mine was never truely listened to either, it sounds flawless but I feel like it's lacking some power. I really want to keep the stock nav though because I have expensive taste and it's going to cost around 200 bucks in wire adapters just to keep all the features like sirius and steering controls. I might end up going that route at some point if it means better sound quality though.
Thanks for the tip on massivespl I'll hit him up for sure.
Fosscore
I second massivespl for audio advice. I hit him up a number of times over the last few weeks via PM and he was right to the point with answers including things I had missed.
adventurenali92
Big Bear Lake, ca
I have the same expensive tastes for stereo setups. I wanted to retain all the stock features like steering wheel controls. The module didn't cost too much for that. Anyways I went with a clarion unit and the sound quality is quite a bit better than stock. And I love it! So if you end up swapping out the head unit and do the modules and such, it's very much worth it! My clarion unit has bluetooth, and I stream music from my iPad and It's absolutely awesome! Sounds fantastic!
05Single
afraid of the dark
Yea like I said I have bose and retained my steering wheel controls. $100 adapter module for the bose. My entry level double din pioneer was $150. makes a huge difference in sound loudness and quality with just the deck on stock speakers.
Your factory deck is very nice but we both know eventually going to go aftermarket, so just use that money for an aftermarket deck to begin with :imo:
BealT1
BealT1
Very tempting, if it makes as much of a difference as you guys say it does.
sher
