justarigger
what up guys. shopping for some new rubber . just wanted some opinions on what you run or ran on your hoe also what i should look for and or stay away from. once again thanks for the input .
This fall I rented a 2010 Tahoe Lt for a trip out West to Wyoming. The truck had about 30k miles on it and Goodyear Wrangler HP OEM tires on the standard 17" rims. I put on 4000 miles overall for the trip and had 2 flats. The flats happened on maintained gravel numbered county roads in Wyoming (in fact the same road within a few miles of each other). Neither of the flats could be repaired so new tires were required. These tires should not be used for even gravel roads, let alone off-road applications. The US Bureau of Land Management agent in that area of WY told me they switched all their vehicles to 10-ply equivalent tires to fix the flat problem.
When I finally do buy my Yukon with 20's or 22's, then I am also going to buy a set of 17" wheels with 10-ply tires for my trips out West.
