Best HID's
TaBro
West Palm Beach
You should also consider getting the 55w LED's for low beam. As easy to install as halogens and much brighter. No ballasts, or relays, or canbus, or cutting dust covers involved.
Sent from my SM-G930P using Tapatalk
I agree - I too prefer HIDs but there always seemed to be an issue. So I ordered new dust caps and went to LEDs;
ICBEAMER JDM H11 6000K 30000K CANBUS CREE COB LED KIT Low Beam Fog Light Bulbs White... https://www.amazon.com/dp/B01KAIY7IW/ref=cm_sw_r_sms_c_api_tByoybNSCN8KG
35W. Sure the light doesn't project as far but it's still 100x better than stock and everything fits nicely behind the dust cap.
I've had these in for month and a half (~3k Miles) and no issues. Anyways these are cheap enough you can buy two sets and keep one in the car in case something goes wrong.
Color is preference- I like 6k lows and 4300k fogs. Not too blue and not too yellow.
Denali132
Denali132
Banned
TaBro how hard is it to get to the passenger headlight. That's what I'm concerned with doing it myself
Sent from my SAMSUNG-SM-G935A using Tapatalk
pro510
It's a bit of a pain. Disconnect the hose and pull the filter box out with a good tug. Once you've done it once it's really easy.
TaBro
West Palm Beach
It's very simple but the force required to remove the airbox initially can make it seem like you're going to break something but you won't - just make sure you disconnect the rubber flex pipe from the air box and that the two radiator hoses going over are clear before you yank up. Also be careful with the clip that holds in the air sensor. There is also a grey plastic wire guide holding that wire to the airbox that needs to be removed; you should see it as soon as you get the box off the plate which it snaps onto.
Putting the air box back in requires a good amount of force too. You will see the nubs on the airbox and the holes where they have to line up. I like to place the box so that the nubs are close to the holes and then shimmy it around a bit until it feels like it's in place and then I get a stool to push it down with my full weight - you should feel or hear a click.
Hope this helps - good luck!
Denali132
Denali132
Banned
Thank you all for the info, my lights should be here in a few days ! Thanks again this is why I love this forum to help everyone!
Sent from my iPad using Tapatalk
Denali132
Denali132
Banned
Thanks again Angel you've been very helpful!
Denali132
Denali132
Banned
What do yo think would be a good price for a shop to paint the chrome around my windows and the front grill Angel?
AngelXL
I don't know if they going to charge you for the project or hourly.
Just make sure to check to shops.
Interlakejay
