Best route to get leveled - 2" rear drop on NNBS LTZ w/ AutoRide
THE YETI
Director of Operations
South FL
Felix, we have 2" spindles up front which did absolutely NOTHING to alter the ride. Just sets the wheel hub 2" higher into the fender. Don't be afraid to drop the front 2", u will NOT notice any difference at all.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
OK, I have a 2008 Tahoe LTZ with AutoRide so what do I need to do exactly to achieve a leveled/cleaner look without messing with my front suspension and retaining the best ride? Do I just need springs? If so, when I change them, will my ride quality be worse then stock? I'm ready to pull the trigger on this but I haven't done it because of the AutoRide issue with the air compressor airing up more then it needs after modifying the suspension. I hear belltech is the best for this, does anyone disagree? Thanks for the input/help guys, it's truly appreciated.
Um hello? Have you not seen my truck? Beltech 2/3 kit. The beltech kit came with rods for the autoride. Of course i didnt use it cause i dont have it. As for the front, Everything stays the same. Theres no added or changed angles to the suspension. As you can see in the comparison of spindles, the wheel just sits higher into the wheel well. Everything stays the same as teh stock spindle. Hope that helps
picture.php
Administrator
Sumo (or Supercharged for that matter)....did you install the drop yourself or did you have someone do it? If you did it how hard or easy was it?
sumo
rhode island
Sumo (or Shoercharged for that matter)....did you install the drop yourself or did you have someone do it? If you did it how hard or easy was it?
done it myself. I have access to a lift and all my tools are at my work and i gave myself a alignment after too. Also it depends what size tires you gonna use as your gonna need to trim the Upper and lower ball joint studs if you have 4x4 and if you plan on using any rims size smaller than 20.
Administrator
I'll eventually end up in a 20" rim. Would I need to trim even with that rim? If so, sounds like if I, too, went with a 2/4 or 2/3 drop I'd need to get rims first then look at the drop, right? Also, my tools consist of an assortment of sockets, and other very wrenches and screwdrivers. Are there any "specialty" tools that you needed to use? I have nothing "fancy" like impact wrenches or anything like that but can do quite a bit myself and do have a bit of mechanical ability.
felixgun
felixgun
Lafayette, LA
Do you have autoride?
sumo
rhode island
impact will make it a lot easier. No specialty tools needed except for patience
Sweet_N_Low
I am working on video I did when I installed my 2/3-4. I did springs and struts so the front won't help but the rear should be the same, although I don't have auto ride. I will try to post the video today.
BMPGBH
