Best route to get leveled - 2" rear drop on NNBS LTZ w/ AutoRide
soulsea
Bar
And yes like ive said and done
My rear belltech kit and you use the spacers that come with the kit and adjust the links to 3.25 inches instead of 3 inches and you will have a 2 inch drop.
Hi Tony ... in your experience, that configuration will make my front and rear fenders level to the ground?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you need to measure the truck with 1/2 tank of gas on level ground. From ground to fendelrip both front in rear. THe rear autoride kits are rated 2.5 to 3.5 inches. By adjusting the links you can get 2.
Have you measured your truck yet from ground to fenderllip?
soulsea
Bar
No not yet ... I'll do it tomorrow on level ground and post results.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
your rear is prob 1.75 higher then front.
soulsea
Bar
That's what I'm afraid of Tony ... that the rear will end up being slightly lower than the front which I do not want. It's weird though, that McG 2" rear leveling kit doesn't make the non autoride trucks sit lower ... I wonder why that is. :think:
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you can get 1.5 at highest setting in rear
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob just measure your truck as it sits now.
Daddyyukon92
