Best way to remove headlight housing?
Burbin
I just purchased some retrofit headlights and wanting to know the best way to remove my headlight housing on my 2013 suburban? I found this on YouTube just wanted your thoughts http://youtu.be/Vwr8hN8Dtsc
Ben
PCB, FL
Gotta remove the bumper to do it correctly
B
Burbin
Ben,
Is there a "How to" video or write up on removal of front bumper cover?
Pockets
West Ga
Why are you taking bumpers off when you're drunk? Shouldn't you be adding bigger bumpers?
B
Burbin
K thanks, I'll keep searching wish it was a sticky
fiatdale
Houstons Best
Houston
Six 10mm bolts on the top (grille and bumper), two 10mm under the truck that mount to the rebar, two 7mm on the sides, and 3 clips on the sides. Remove all, pull each corner of the cover out away from the fender. Go to the front of the vehicle and pull the cover straight out. If you have fog lights, don't forget to unplug them prior to removing the cover.
Ben
PCB, FL
He forgot to mention you have to remove the plastic air dam under the hood it's got all the stickers on it for belts and shit. 10 plastic rivets or something like that.
