Black bear tune help..
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Im getting a tune in june and i wanted to know if theres anything i should get done or do before getting it so it preforms better and the engine can handle it...btw my 01 Lt is fully stock under the hood so is hasn't been touched..
also how do i know what tune set-up should i go with?
any help is well appreciated !!!!!!! thanks guys
blueflamed03
Oklahoma
Garry,
fuel filter, plugs and wires and clean MAF, if you over 100K.
Get ready, you'll love it :)
Physh1
Get MAF cleaner...don't touch the wires & just let it air-dry...
NGK TR-55's are popular plugs...
Stock wires are good replacements...no need for fancy wires really...
I would recommend getting Vette servo & installing it in your transmission...a trans service would be good too...search 'vette servo' for all the info...cheap & very helpful mod...
Cameron
Physh1
Amazon or eBay probably will find you the best prices on Delco parts...
redemn93
Jupiter, Fl
use the stock delco iridium replacement plug if you want another 100k miles out of them. i dont believe the TR-55 are even a platinum plug. you will spend a little for them but will be done for another 100k.
i used auolite (the other ford OE) plug wires cause thats all the store had. still working fine 30k miles later. someone gave me a set of 9mm taylor wires. still sitting in the garage. i really dont see why i would need them on a stock motor. i may throw them in just cause.
blueflamed03
Oklahoma
agree, I'd re-use ACDelcos, they have lasted 100K +, so why not trust em again. :)
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Thank you guys im going to keep reasearching so I can figure out tge install on this stuff....haven't done anything under the good yet so you know.. all comments are appreciated!
Sent from my SCH-I500 using Tapatalk
Smityinms
