- Joined
- Aug 2, 2018
- Posts
- 7,538
- Reaction score
- 10,338
And, even if you have a need to program a control module using the Tech 2, you still do not need to install the supplied software. Programming is achieved through a dongle, as @Fless stated, to connect the Tech 2 to a PC USB port. However, connecting to TechLine Connect, the source of programming data, is achieved directly through a web browser on the PC, such as Chrome, Edge, etc.There are specific USB dongles that will work to connect a Tech 2 to a PC, and a few posts on here list at least a few. Sometimes the Tech 2 needs to know which COM port the dongle is using.
To mirror what @Joseph Garcia notes, the online Techline, or whatever it is now, connection through the PC is generally not needed to troubleshoot. Typically needed only to program.
For dongles that are known to work, see these two posts:
https://www.tahoeyukonforum.com/threads/tech-2-purchase.111719/post-1346032
https://www.tahoeyukonforum.com/threads/bcm-programming-who-and.129584/post-1622353
EDIT: for programming info, see this thread:
Migration from ACDelco TDS to GM Techline Connect for Tech 2 Users
Hi Folks, As you probably know, ACDelco TDS (TIS2Win) site for Service Programming Software (SPS) has been retired, effective September, and current subscription holders need to migrate to its replacement GM Techline Connect. Below, I offer you the process that I used to perform this...www.tahoeyukonforum.com
