Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Blazed
Blazed
Accepting Donations
The only thing I could think of is you might could over travel into the fender well...
Idk other than that.
---------- Post added at 03:35 PM ---------- Previous post was at 03:33 PM ----------
But then that might happen any way with any strut cause I know it happens to me sometime.
Modded
That Guy
No you won't. Not with a 2" drop only. Not even close.
Now if you have those installed and set to 2", plus 2" drop spindles, you may have a bit on an issue with 24s or larger.
For example, I have a 32.9" tire and my front fenders (soon to be front and rear) sit at 33.75". That's less than an inch off the tire and I only travel into the fenders when I hit ugly dips. When I had +35 offset wheels, I rubbed a lot less.
---------- Post added at 01:37 PM ---------- Previous post was at 01:37 PM ----------
You should only travel into the fender excessively if you cut the front bumpstops too slim.
Blazed
Blazed
Accepting Donations
That's what I meant like over dips and stuff
Goodinblack
I Like Tacos
Dirty South
@ Blazed....... Saw this on GMFS.........
The only down side to the mcg spindles is they have less turning radius and the top nut for the hub cant be used, the spindles come with a stud you have to install into them. Wife rode in it for the first time the other day with the new drop and couldnt believe it. She would never wanna ride in the truck before.
@ Modded.......... I saw this on GMFS too.....
The biggest problem I see on these trucks is a combination of a few things, some have already been mentioned above and I agree with.
Most aftermarket coil springs due to the increase in spring rate and shorter loaded height create a more harsh ride.
Oversize wheels and tires being run with the original strut (which is marginal at best even in oem trim) is just too much for it to handle. Factory struts weren't dampened to handle that much weight so they really struggle to control a suspensions oscillations.
Coil relocators only hinder the factory strut even more by limiting the overall travel of the factory strut which will also affect ride quality.
Thoughts on the last statement please.
Blazed
Blazed
Accepting Donations
Well I kinda want to know what you meant with that quote about the spindles.
And ok. So say you do the coil relocator and get the drop you want and then maybe you get a strut relocator to get that travel back? Just a thought. There is always the spindle and then a one inch lift strut. That seems the easiest solution.
Goodinblack
I Like Tacos
Dirty South
Too much $$$.
---------- Post added at 03:42 PM ---------- Previous post was at 03:41 PM ----------
So say you do the coil re locator and get the drop you want and then maybe you get a strut re locator to get that travel back?
I think the coil and strut re-locator are the same thing. :think:
Modded
That Guy
The part about the stud on McG spindles is tue. The upper hub bolt is converted to a stud to save on spindle height. It is advantageous in the end though because the only way to avoid that is a taller spindles (like BT) which can cause alignment issues.
Increased spring rates do cause a stiffer ride. But that is unavoidable because like the post mentioned, almost all drop springs due have increased spring rates. The shorter loaded height is not important on our SUV rear suspension setups as long as you have the free travel mod (for 4" plus drops) to increase suspension travel.
Coil relocators do effect ride quality because the front strut coil lower mount is dropped lower. This makes the strut shaft push deeper into the shock and limits suspension travel. It does not affect ride quality too badly until the strut is relocated for 2" or more, than shit starts to get harsh.
You'll be fine with the relocators. You will just need better performing shock for the front also. Stockers will not cut it.
Blazed
Blazed
Accepting Donations
Too much $$$.
I was referring to relocating the coil lower on the strut and relocating the top of the strut higher to gain strut travel back.
Status
ezmoney1981
