Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Modded
That Guy
No thread jack, but all the info is in here anyway.lol
After reading I am ready to start planning for my drop, but I need a little help.
So I started putting aside for my drop. Which will be 2/3 daily driven.
Since I have 55k miles:
Front:
Belltech SP drop struts at -2inch
Rear:
Belltech 5305 coils with 1.5 inch spacer
Bilstein 5100 shocks
Also no shock extenders because of shorter 5100 shocks like Modded has.
Atleast I believe they are shorter.
I think this would be a good start to do it right and save some $$$ at the same time.
I just can't find the shorter 5100's
http://www.ajusa.com/Bilstein-Monotu...67a8q6b88.html
I had sent a message to Modded, but thats before I read what went down.
I will respond to you because I have not turned off my *** and VMs and don't want to ignore a direct question because of Tony and the Admin.
First off, with the 5305s you want a 1" spacer to be able to get to a 3" drop. A 1.5" spacer will take you to right over 2.5".
You want 5100 universal shocks. They are not a direct replacement since they are shorter.
The part number is: BE5-6252-H5 5100
Everything else you posted is fine.
Goodinblack
I Like Tacos
Dirty South
Hey Neo.......Hey Bud....
Is this the part number I can use too if I am lowered just 2 inches in the rear?
I believe the regular 5100 shocks are actually LONGER right?
Because they say "0-1 inch lift"........So they would be slightly longer to accommodate the extra lift some people do. Right?
---------- Post added at 03:06 PM ---------- Previous post was at 02:54 PM ----------
From AJUSA.COM
$72.58
Monotube Shock Absorber
Series: 5100 Series; Rear Lifted Height: 0-1"; Excludes Z55 Autoride Suspension Package; Rear; 46mm Monotube Shock Absorber
Internal Design: Monotube
Collapsed Length: 15.55 in / 395 mm
Extended Length: 24.33 in / 618 mm
Boot Included: Black Bellows
Mounting Kit: No
Spring Seat: No
Reservoir: No
Finish: Zinc Plated
Supercedes: F4-BE5-F265-H0
Part #: 24-187237
Modded
That Guy
Yeah the regular replacement ones are longer.
For your amount of drop, you could get part number BE5-A463-H5 5100, or run the ones I have with extenders.
Blazed
Blazed
Accepting Donations
Goodinblack only has two inch drop tho?
Blazed
Blazed
Accepting Donations
If anything wouldn't he need longer shocks than yours...?
Goodinblack
I Like Tacos
Dirty South
Wait, so since I am not on my meds today, what should I get again?
PN Please.
I only have a 2 inch drop and will never go lower, maybe back to stock, but never lower.
Status
tdeaton3
