Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Blazed
Blazed
Accepting Donations
Wait, so since I am not on my meds today, what should I get again?
PN Please.
I only have a 2 inch drop and will never go lower, maybe back to stock, but never lower.
Than just get stock replacements and belltech extenders.
Fearz
Houston
I will respond to you because I have not turned off my *** and VMs and don't want to ignore a direct question because of Tony and the Admin.
First off, with the 5305s you want a 1" spacer to be able to get to a 3" drop. A 1.5" spacer will take you to right over 2.5".
You want 5100 universal shocks. They are not a direct replacement since they are shorter.
The part number is: BE5-6252-H5 5100
Everything else you posted is fine.
So I get the BE5-6252-H5 5100 and I should be good to go?
If not I know the HD's and extenders works.
Thanks again Modded.
Modded
That Guy
Yes I highly recommend them. You will need a few assorted washers, bolts, and nylon lock nuts to install them because they use smaller hardware than the factory bolts. After that, you're good.
Blazed
Blazed
Accepting Donations
No problem lee.
guys i have more white on white competition im likely to be destroyed by yet again...
When i finally finish it wont even be special anymore.
Status
schmaltzy82
