Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Blazed
Blazed
Accepting Donations
I moved it over but it looked like my truck isn't low enough for how short these are.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
They work fine from 3-5 inches. mines at 3 7/8 and ive been selling them with the 3-4 belltech kits for a while and I get guys saying mine broke like yours on passengers side and this happens when the bar isnt moved over on the drivers side mount and or when they put the swaybar on they do it wrong. The swaybar should be sitting on the outside of pass side endlink toward tire not inside.
Blazed
Blazed
Accepting Donations
I wasn't saying for sure that was why it broke it just looked that way because of the marks on the sway bar itself.
My sway bar is absolutely moved over.
I changed back to the stock end links today in my auto tech class and my teacher said he thought the same thing as me. Ill take pictures of where it is mounted and where it was rubbing.
---------- Post added at 03:59 PM ---------- Previous post was at 03:49 PM ----------
And I just walked back in but the sway bar isn't moved quite an inch but if it was moved any further it would be hitting that cup on the drivers side even more. With the djm end links on the sway bar is pointed up just a touch.
I think I'm just gonna cut the stock end links and weld them the perfect length and side by side so they have the offset.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you make it longer then will point down. Either way if you want a new link shoot me a pm and ill get it going for you.
Blazed
Blazed
Accepting Donations
I want to shorten the stock links to the perfect length for my drop and it'll still have the ball joints like stock.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Where did you have the swaybar mounted on inner or outer side?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
DO you have pics of how you had pass side swaybar set up at the endlink? the 5/6 inch kits i have set up dont have this issue and a lot less space there so im trying to see what exactly happened. My truck cleared also in back and im about same height as you.
Blazed
Blazed
Accepting Donations
I'm on my phone but I think there are pictures in my photo albums in the help album.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
didnt see it there. ill check later on from.computer
Status
antennabob
