Body drop ???s
Jackson Tn.
Im in the middle of my body drop and getting ready to reinstall when i noticed 4 rigid metel lines on top of the frame rail under the drivers door in a plastic keeper not flexable at all also the metel filler and vent tube are between the frame and body in the back along with an assortment of other goodies up front under the firewall along the frame. I seen a few other ppl did this body drop on here but no metion of any of this in there post. rigid lines might clear not a 100% sure but that fuel filler looks as though its gonna get crushed. Trying to wrap this up so can install 4/5.5 kit this wknd. Any info appriciated thanks
MeanGreen03
TX
I didn't have any issues with this. The only thing I moved was a loom of wires. The emergency brake line was stretched pretty good when lifting up the drivers side. Maybe you saw my write-up? If you do have anything in the way it will have to be moved. Also if you are planning on changing the servo in the transmission I would do that now. If not you will have to beat the floorboard to allow enough room to get the whole assembly out.
rocketfish0477
Jackson Tn.
Thanks for the link. I seem the loom and moved it already. U didnt have a box under your drivers floorboard with like 4 or 5 rigid metel lines coming out of it heading out to the topside of your frame rail under drivers door area? and your gas filler tube was fine? i dont have s-10 mounts just removing factory rubber cutting cups deep and placeing 1/8 in rubber sheets inbetween like i seen on another post here. Trans servo?? should i address this now by making clearance. Is a bunch of clearance needed?
---------- Post added at 11:26 PM ---------- Previous post was at 11:19 PM ----------
BTW Nice looking ride
rocketfish0477
Jackson Tn.
heres some pics of what i was talking about:
MeanGreen03
TX
Can you post larger pictures? I'll go try and look at mine and see if I can figure out what you're talking about. The gas filler tube isn't a problem. I don't think the rigid metal lines you are talking about will be a problem either. Your body shouldn't drop down that far to sit on the frame.
schimme
