GMOWESME$
The PD probably had the taillights wired with some sort of flashers.. thats probably why there were green and yellow wires running all the way to the firewall.. Just reading through your thread and from what I understand the passenger tailight is fed from the driver's so.. if you have voltage from that point its between the driver and passenger side. Unless you already covered that my guess would be that they had those flashers in also... I know you said you had no voltage at the connector but on mine the connector doesnt stay in the circut board straight so as soon as I get it working and put together I'll hit a bump and it moves the slightest and then it doesnt work and I get the fast flash. So,,, I feel your pain bro. Good luck
