latvius
Hmmm...good info - thanks! Definitely cheaper than buying all the other stuff!
Correct. Open the cap on your master, connect your tubing to the bleeder barb and crack it, and let'er run out. If your length of tube is long enough to reach down into your 'solo' cup and you want to feather the peddle a bit you can, just pour a little fluid into the bottom of your cup as not to suck air into the system.. really though once the tube fills with fluid, no need to pump. Allow the old to come out until clean, keeping an eye on the level in your master and work your way from the caliper furthest from master to the closest..
