Brake upgrade options?
2016YUKONSLT
So I lowered my 16' Yukon and put on 24" Futures and now the brakes just look tiny. Are there other options beside Wilwood or Baer kits that are $2k+ just for Fronts? Is it possible to do a Z06 conversion on the these?
Kpwweb
GM has a $5k Brembo kit just for fronts.
SSBC MIGHT make a kit, but no one is sure yet...
2016YUKONSLT
2016YUKONSLT
How does increasing the diameter help slow it down quicker when using the same caliper?
NowZoomer
I thought you're doing it for looks
On all modern cars, a brake upgrade rarely results in any meaningful reduction in stopping distance - usually, you'll see <10 feet if we're talking about the 1st panic stop
But watch out for cheap kits where you'll actually see longer distances since the new setup weights more than OEM
A brake upgrade helps you on fade and feel, which is important when you're using the brakes a lot like at the track, mountains, towing, etc ... this fade improvement is where an upgrade will help shorten distances vs stock beyond the 1st panic stop
2016YUKONSLT
2016YUKONSLT
I was doing it for looks. Just curious how a rotor diameter increase slows the vehicle down quicker.
The caliper and the same size pad are used. The surface area of contact is the same. I guess i don't fully understand how leverage is gained. Is it just because now the pads are hitting an inch farther from the center?
gat0r
DFW
i like the StopTech Trophy Sport Big Brake Kit
still pricey though
think autoanything has 25% off
NowZoomer
You won't see any material difference, but if you're interested academically, search the internet on brake upgrade benefits, lots of headache inducing stuff out there
Damatulli1
