brought out the paint gun oh no!
08grey
Is your paint code 503q? I think our trucks are the same color. I'm having trouble matching mine. The metallic isn't as heavy and prominent enough as it is from the factory. Made the paint myself twice to the tee. Ppg tectron. Going to try global or dupont next.
Ponchonutty
Ponchonutty
New Washington, Ohio
Painting metallics of any color is a very tedious task. You can have a variable from the manufacture. You could also have variables from the place that is mixing your paint. Also how you prep the vehicle and how you spray greatly affects how well it will match. Even raising or lowering air pressure affects how the metallics flow. Mine is very close but not spot on. I originally just wanted to spot in on the fenders but one fender I had to feather to the edge where the door jamb is. Under certain light, you can see a small difference in the hue. When doing something like this, it's best to blend into the next panel and then do a clear overcoat over the entire panel.
08grey
Defeintly did blend into the edge of the quarter but hey. So is your paint code 503q
pickegs
