Budget rebuild items?
Charlie207
Charlie207
LFOD, New Hampshire
I bought mine thru a local drag racer friend that owns a local company and is a Precision dealer. Had to give them my ole TC or get charged for a core.
Ok, so I'd need to find a dealer or shop to order it through. Seems like a middleman fee.
j91z28d1
15% market up on everything unless you're good friends blah.
if you have the part number you want you might get summit racing to drop ship it for you.
Charlie207
Charlie207
LFOD, New Hampshire
Finally started thinking about the top of the engine, and discovered this gem on Sunday... there's a hole in the top of the intake manifold that was covered up with a piece of tape. Not sure how I didn't notice it before, but in my defense I pulled off the manifold and put it in a box with the hardware when I first got the engine in my basement, and haven't thought about it since.
You can see the tape covering the hole in this photo from the middle of March.
Up close:
I spent a while reading up on how others have dealt with this issue (holes and/or cracks), and the material is glass-fiber reinforced nylon (PA6-GF30). There's some plastic epoxy that you can schmoo together and build a plug to seal it up. Or, you can buy a nylon spatula, and cut out a patch to either epoxy or melt (with a sufficiently hot soldering iron) into place. The manifold is currently soaking in a big container with lots of degreaser.
donjetman
Those lifters sound too good to be true.
GM Bowtie lifters # 88958689 are $538.
Charlie207
Charlie207
LFOD, New Hampshire
Charlie207
Charlie207
LFOD, New Hampshire
I just realized that's a totally different part#/part.
Racing vs. OEM lifters, not that it diminishes your point. I've been stalking that website/company for a while, and it seems like folks in the Corvette forums have had good luck with them.
It wouldn't surprise me if these are just "blems" (hence the "no factory packaging"). I interned at Ruger for a summer back in college, and there's an internal-only list of blem guns that comes out every month or so, that can't pass final-assenbly QC for visual reasons, so employees can buy them for huge discounts, like 50%+ off depending on the model. If I wasn't a poor college kid at the time I would have bought them all.
Charlie207
Charlie207
LFOD, New Hampshire
Found a once-used 4,000lb. engine hoist w/extra engine stand for $200 delivered to my door.
Sounds like it sat for a while, but after leaving an 80lb floor jack hanging all evening it only came down a couple degrees, so I'll be at least a little confident I won't fúçk something up.
Bryon Morgan
