NardDog
- Joined
- Mar 26, 2017
- Posts
- 125
- Reaction score
- 119
My truck was burning some serious amounts of oil for a long time. It didn’t ruin the Cats until last year. Since then I ran Amsoils engine flush and my oil consumption has been cut in half. Either the piston rings were stuck or valves were letting oil thru not sure which but the flush really helped me.Replace your drivers side valve cover with the dorman 264-969 as a start for the oil burning issue. Change your plugs and cylinder 5 will most likely be getting oil build up on it from the oil burning problem causing the misfire, then run penzoil 5w30 synthetic high mileage formula with a half bottle of Lucas synthetic oil stabilizer. That is the best formula I could come up with after trial and error for the typical oil burning problem on some of these engines. I did it this way to try and make the oil stickier so it doesn't spash around as much, and it has been taking engines that were burning a liter of oil per 800 kms (i am Canadian eh,) down to a liter of oil every 2000 to 2500 kms, wich is livable.
Then pull your oil pressure sensor and oil pressure screen, throw the screen in the garbage, put in a new sensor with no screen, and change your oil every 4 thousand miles.
Then turn off the dod system with a tune.
